HP Chromebook 11 G6 EE - Illustrated Parts
HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Labels
The labels affixed to the computer provide information that may be needed when troubleshooting system problems or travelling internationally with the computer.
Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
  • Service label—Provides important information to identify your computer. When contacting support, you may be asked for the serial number, the product number, or the model number. Locate this information before you contact support.
    Your service label will resemble one of the examples shown below. Refer to the illustration that most closely matches the service label on your computer.
Figure : Identifying the service label contents
Component
(1)
Model number
(2)
Serial number
(3)
(4)
Warranty period
Computer components
Figure : Identifying the computer components
Item
Component
Spare part number
(1)
11.6-in. display assembly: The display assembly is spared at the subcomponent level only. For more display assembly spare part information, see Display assembly subcomponents.
(2)
Keyboard/top cover(includes keyboard cable):
For use in Belgium
L14921-A41
For use in Brazil
L14921-201
For use in Canada
L14921-DB1
For use in the Czech Republic and Slovakia
L14921-FL1
For use in Denmark, Finland, and Norway
L14921-DH1
For use in France
L14921-051
For use in Germany
L14921-041
For use in India
L14921-DD1
For use in Israel
L14921-BB1
For use in Italy
L14921-061
For use in Latin America
L14921-161
For use in the Netherlands
L14921-B31
For use in Portugal
L14921-131
For use in Romania
L14921-271
For use in Russia
L14921-251
For use in Saudi Arabia
L14921-171
For use in South Korea
L14921-AD1
For use in Spain
L14921-071
For use in Sweden and Finland
L14921-B71
For use in Switzerland
L14921-BG1
For use in Taiwan
L14921-AB1
For use in Thailand
L14921-281
For use in Turkey
L14921-141
For use in the United Kingdom
L14921-031
For use in the United States
L14921-001
(3a)
TouchPad (does not include cable)
L14922-001
(3b)
TouchPad bracket
L18300-001
(3c)
TouchPad cable (included in the Cable Kit, spare part number L14906-001, and includes double-sided adhesive)
(4)
Speakers (include cables)
L14920-001
(5)
Battery (2-cell, 47-WHr, 6.15-AHr, Li-ion, includes cable)
917725-855
Battery connector tape (not illustrated)
L14905-001
(6a)
USB port board (does not include cable)
L14923-001
(6b)
USB port board cable (included in the Cable Kit, spare part number L14906-001, and includes double-sided adhesive)
(6c)
USB port board bracket
L14359-001
(7)
System board (includes processor, on-board Intel 7265ac 2×2 + Bluetooth 4.2 (non-VPro) WLAN module, system memory, eMMC storage, the Goodle Chrome operating system, and replacement thermal material):
Equipped with an Intel Celeron N3450 1.10-GHz (turbo up to 2.20-GHz) quad core processor (2400-MHz, 2.0-MB L2 cache, 6.0-W), an Intel graphics subsystem with UMA video memory, 8-GB of system memory, and 64-GB of eMMC storage
L15856-001
Equipped with an Intel Celeron N3450 1.10-GHz (turbo up to 2.20-GHz) quad core processor (2400-MHz, 2.0-MB L2 cache, 6.0-W), an Intel graphics subsystem with UMA video memory, 8-GB of system memory, and 32-GB of eMMC storage
L15855-001
Equipped with an Intel Celeron N3450 1.10-GHz (turbo up to 2.20-GHz) quad core processor (2400-MHz, 2.0-MB L2 cache, 6.0-W), an Intel graphics subsystem with UMA video memory, 4-GB of system memory, and 32-GB of eMMC storage
L15854-001
Equipped with an Intel Celeron N3350 1.10-GHz dual core processor (2400-MHz, 2.0-MB L2 cache, 6-W), an Intel graphics subsystem with UMA video memory, 8-GB of system memory, and 64-GB of eMMC storage
L15853-001
Equipped with an Intel Celeron N3350 1.10-GHz dual core processor (2400-MHz, 2.0-MB L2 cache, 6-W), an Intel graphics subsystem with UMA video memory, 8-GB of system memory, and 32-GB of eMMC storage
L15852-001
Equipped with an Intel Celeron N3350 1.10-GHz dual core processor (2400-MHz, 2.0-MB L2 cache, 6-W), an Intel graphics subsystem with UMA video memory, 4-GB of system memory, and 32-GB of eMMC storage
L15851-001
Equipped with an Intel Celeron N3350 1.10-GHz dual core processor (2400-MHz, 2.0-MB L2 cache, 6-W), an Intel graphics subsystem with UMA video memory, 4-GB of system memory, and 16-GB of eMMC storage
L15850-001
(8)
Heat sink (includes replacement thermal material)
928840-001
(9)
Bottom cover:
In chalkboard gray finish
L14901-001
In delicate orange finish
L14904-001
Rubber Foot Kit (not illustrated, includes bottom cover feet)
L20220-001
Item
Component
Spare part number
(1)
Display bezel
L14912-001
(2)
Webcam/microphone module (does not include cable; includes double-sided adhesive)
L07235-001
(3)
Display panel bracket
L14913-001
(4)
Display panel (does not include display panel cable):
For use only on computer models equipped with an HD BrightView TouchScreen display assembly
L14918-001
For use only on computer models equipped with an AntiGlare TouchScreen display assembly
L22362-001
For use only on computer models equipped with non-TouchScreen display assembly
L14917-001
(5)
Display panel cable:
L14916-001
L14915-001
L14914-001
(6)
Display hinges (2)
L14907-001
(7)
Display back cover (includes the wireless antenna cables and transceivers):
The webcam/microphone module cable is included in the Cable Kit, spare part number 14906-001.
L14908-001
L14911-001
Miscellaneous parts
Component
Spare part number
45-W AC adapter (non-PFC, USB Type-C, 3-pin)
934739-850
Cable Kit (includes TouchPad cable and USB port board cable)
L14906-001
Power cord (C5 connector, 1.00-m):
For use in Argentina
L19357-001
For use in Australia
L19358-001
For use in Brazil
L19359-001
For use in Denmark
L19360-001
For use in Europe
L19361-001
For use in India
L19363-001
For use in Israel
L19362-001
For use in Italy
L19364-001
For use in North America
L19367-001
For use in the People’s Republic of China
L19368-001
For use in South Africa
L19369-001
L19366-001
L19370-001
For use in Taiwan
L19372-001
For use in Thailand
L19371-001
L19373-001
Rubber Foot Kit (includes bottom cover rear foot strip)
L20220-001
Screw Kit
L14919-001
