    We are upgrading our website
    Fix Windows 10 Update Issues
HP Pavilion Gaming - 15-ec0031ax Product Specifications
8WH61PA
AMD Ryzen™ 5 3550H with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
512 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Realtek Wi-Fi 5 (2x2) and Bluetooth® 5 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (HP Sleep and Charge); 1 AC smart pin; 1 HDMI 2.0; 1 headphone/microphone combo; 1 RJ-45
36 x 25.7 x 2.35 cm
Starting at 1.98 kg
135 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
Video Playback Battery life
Up to 10 hours
HP TrueVision HD Camera with integrated dual array digital microphone
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP PC Hardware Diagnostics Windows
Pre-installed software
iQiyi
