Model name
HP Color LaserJet Pro M255dw
7KW64A
- ${title}
- ${title}
- ${title}
- ${title}
Product Specifications for the HP Color LaserJet Pro M255dw (7KW64A)
Product naming
What's included and accessories
What's in the box
HP Color LaserJet Pro M255dw printer; Introductory HP LaserJet cartridges: 700 colour composite (C/Y/M) page yield and 800 page yield black; Installation guide; Power cord; USB cable
Connectivity
Ports
Hi-Speed USB 2.0 port; Built-in Fast Ethernet 10/100Base-TX network port; 802.11n 2.4/5GHz wireless; Walkup host USB port
Wireless capability
Built-in 802.11 b/g/n; Authentication via WEP, WPA/WPA2, or 802.1X; Encryption via AES or TKIP; WPS; Wi-Fi Direct
Storage device and direct print support
Front-facing USB/Flash drive; USB printing
Environmental
Acoustic power emissions (active, printing)
6.4 B(A) (colour/simplex); 6.3 B(A) (monochrome/simplex); 6.3 B(A) (monochrome/duplex); 6.3 B(A) (colour/duplex)
Recommended operating humidity range
30 to 70% RH
Non-Operating Humidity Range
0 to 95% RH
Recommended operating temperature range (Celsius)
15 to 27°C
Storage temperature range (Celsius)
-20 to 40°C
Environmental specifications
Mercury-free
Memory
Memory
256 MB DDR, 256 MB NAND Flash
Maximum Memory
Mobile printing capability
Mobile printing services
HP ePrint; Apple AirPrint™; Mobile Apps; Mopria™ Certified; Wi-Fi® Direct printing
Networking
Network protocols, supported
TCP/IP, IPv4, IPv6; Print: TCP-IP port 9100 Direct Mode, LPD (raw queue support only), WSD; Discovery: SLP, Bonjour, WS-Discovery; IP Config: IPv4 (BootP, DHCP, AutoIP, Manual), IPv6
Paper handling
Input capacity
Up to 250 sheets (25 mm stack height) in Tray 2
Standard input capacity (envelopes)
Up to 15 mm (recommended only 5 envelopes or less at a time)
Output capacity
Up to 100 sheets (10 mm stack height)
Media sizes supported (metric)
Executive (184 x 267 mm); Oficio 8.5x13 (216 x 330 mm); 4 x 6 (102 x 152 mm); 5 x 8 (127 x 203 mm); A4 (210 x 299 mm); A5 (148 x 210 mm); A6 (105 x 148 mm); B5(JIS) (182 x 257 mm); B6(JIS) (128 x 182 mm); 10 x 15cm (100 x 150 mm); Oficio (216 x 340 mm); 16K (195 x 270 mm; 184 x 260 mm; 197 x 273mm); Postcard(JIS) (100 x 147 mm); Double Postcard(JIS) (147 x 200 mm); Envelope #10 (105 x 241 mm); Envelope Monarch (98 x 191 mm); Envelope B5 (176 x 250 mm); Envelope C5 (162 x 229 mm); Envelope DL (110 x 220 mm); A5-R (210 x 148 mm)
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media types
Paper (bond, brochure, coloured, glossy, heavy, letterhead, light, photo, plain, preprinted, prepunched, recycled, rough), transparencies, labels, envelopes, cardstock
Media weight supported (metric)
60 to 163 g/m² (Uncoated/Matte, recommended), however up to 175 g/m² Postcards and 200 g/m² HP Matte is allowed in the driver; 60 to 163 g/m² (Coated/Glossy, recommended) , however up to 175 g/m² Postcards and 220 g/m² HP Glossy is allowed in the driver.
Paper handling - duplexer
Recommended media weight, duplex (metric)
60 to 120 g/m² (recommended); 60 to 200 g/m² (allowed)
Physical dimensions
Maximum dimensions (W x D x H, metric)
392 x 475x 297 mm
Weight (metric)
14.8 kg
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology; Instant-on Technology
Internal (built-in) Power Supply
Power supply
220 to 240 VAC (+/- 10%), 50 Hz (+/- 3 Hz), 60 Hz (+/- 3 Hz)
Power consumption
337 watts (active printing), 7.2 watts (ready), 0.8 watt (sleep), 0.6 watt (Manual-Off), 0.05 (Auto Off/Manual On), 0.6 watt (Auto Off/Wake on LAN)
Print cartridges
Number of print cartridges
4 (1 each black, cyan, magenta, yellow)
Replacement cartridges
HP 207A Black LaserJet Toner Cartridge (1,350 yield) W2110A; HP 207A Cyan LaserJet Toner Cartridge (1,250 yield) W2111A; HP 207A Yellow LaserJet Toner Cartridge (1,250 yield) W2112A; HP 207A Magenta LaserJet Toner Cartridge (1,250 yield) W2113A; HP 207X Black LaserJet Toner Cartridge (3,150 yield) W2110X; HP 207X Cyan LaserJet Toner Cartridge (2,450 yield) , W2111X; HP 207X Yellow LaserJet Toner Cartridge (2,450 yield) W2112X; HP 207X Magenta LaserJet Toner Cartridge (2,450 yield) W2113X; HP 206A Black LaserJet Toner Cartridge (1,350 yield) W2110A; HP 206A Cyan LaserJet Toner Cartridge (1,250 yield) W2111A; HP 206A Yellow LaserJet Toner Cartridge (1,250 yield) W2112A; HP 206A Magenta LaserJet Toner Cartridge (1,250 yield) W2113A; HP 206X Black LaserJet Toner Cartridge (3,150 yield) W2110X; HP 206X Cyan LaserJet Toner Cartridge (2,450 yield) , W2111X; HP 206X Yellow LaserJet Toner Cartridge (2,450 yield) W2112X; HP 206X Magenta LaserJet Toner Cartridge (2,450 yield) W2113X;
Replacement cartridges footnote
Replacement 207A cartridge average composite (C/Y/M) declared yield 1,250 and average black yield 1,350 pages; Replacement 207X cartridge average composite (C/Y/M) declared yield 2,450 and average black yield 3,150 pages based on ISO/IEC 19798 and continuous printing. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/learnaboutsupplies.
Printing specifications
Print technology
Laser
Duplex printing
Automatic (standard)
Print resolution (best)
Up to 600 x 600 dpi
Maximum print area (metric)
206 x 346 mm
Monthly duty cycle
Up to 40,000 pages
Print languages
HP PCL6; HP PCL5c; HP postscript level 3 emulation; PWG raster; PDF; PCLm; PCLm-S; NativeOffice; URF
Printer smart software features
6.8 cm (2.7 in) colour touchscreen, Automatic 2-sided printing, Wireless printing, Ethernet networking, Wireless direct printing, HP ePrint, Apple AirPrint™, Mopria-certified, Google Cloud Print, HP Auto-On/Auto-Off technology, HP Smart App, Smart task shortcuts in HP Smart App, HP JetAdvantage Secure Print
Regulatory specifications
Energy efficiency
ENERGY STAR® qualified; EPEAT® Silver
Safety
EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013; IEC 60950-1:2005+A1:2009+A2:2013; EN 60825-1:2014/IEC 60825-1:2014 (Class 1 Laser Product); EN 62479:2010/IEC 62479:2010
Electromagnetic compatibility
CISPR32:2012 & CISPR32:2015/EN55032:2012 & EN55032:2015+AC:2016 - Class B; EN 61000-3-2:2014; EN 61000-3-3:2013; EN 55024:2010+A1:2015
Security
Security management
Embedded Web Server: password-protection, secure browsing via SSL/TLS; Network: enable/disable network ports and features, SNMPv1 community password change; HP ePrint: HTTPS with certificate validation, HTTP Basic Access Authentication; Firewall and ACL; SNMPv3
System requirements
Minimum system requirements for Windows
Windows® 10, 8.1, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows Vista®: (32-bit only), 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows® XP SP3 or higher (32-bit only): any Intel® Pentium® II, Celeron® or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows Server support is provided via the command line installer and supports Win Server 2008 R2 and higher
Minimum System Requirements for Macintosh
Apple® macOS Sierra (v10.12), macOS High Sierra (v10.13), macOS Mojave (v10.14), macOS Catalina(v10.15), 200 MB available hard disk space, Internet required for download, USB
Compatible Network Operating Systems
Windows® 10, 8, 7: 32/64-bit, 2 GB available hard disk space, Internet connection, USB port, Internet Explorer; 2 GB available hard disk space, Internet connection, USB port, Internet Explorer 8; any Intel® Pentium® II, Celeron® or 233 MHz compatible processor, 850 MB available hard disk space, Internet connection, USB port, Internet Explorer 8; Windows Server support is provided via the command line installer and supports Win Server 2008 R2 and higher; Apple® macOS Sierra (v10.12), macOS High Sierra (v10.13), macOS Mojave (v10.14), macOS Catalina(v10.15), 200 MB available hard disk space, Internet required for download, USB; Linux: for more information see https://developers.hp.com/hp-linux-imaging-and-printing; Unix: for more information see http://www.hp.com.
Operating system (supported note)
"Compatible Operating Systems" are not supported with INBOX software, but downloadable from online; Full solution software available only for Windows 7 and newer; Windows Server OS install driver only; Windows RT OS for Tablets 32/64-bit uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software
One-year unit exchange warranty. Warranty and support options vary by product, country and local legal requirements. Go to http://www.hp.com/support to learn about HP award winning service and support options in your region.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
