    Fix Windows 10 Update Issues
HP ZHAN X 13 G2 Notebook PC - Illustrated Parts
Computer major components
HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Details about your computer, including model, serial number, product key, and length of warranty, are on the service tag at the bottom of your computer. See Labels for details.
Figure : Identifying the computer major components
Computer major component part numbers and their descriptions
Item
Component
Spare part number
(1)
13.3-in., FHD, UWVA, touchscreen display assembly:
BrightView, privacy filter, 1000 nits, equipped with webcam/microphone module and WLAN antenna
L56440-001
400 nits, equipped with webcam/microphone module and WLAN antenna
L56436-001
(2)
Power button board (includes holder and cable)
L56451-001
(3)
Keyboard/top cover with backlight and privacy filter for use in the United States (includes backlight cable and keyboard cable):
L65217-001
Keyboard/top cover with privacy filter for use in the United States (includes keyboard cable):
L65216-001
(4)
USB port bracket (included in the Bracket Kit, spare part number L56447-001)
(5)
I/O port bracket (included in Plastics Kit, spare part number L56454-001)
(6)
NFC module (includes cables)
L56453-001
(7)
Touchpad (includes touchpad cable)
L56458-001
(8)
RTC battery
unavailable
(9)
Fingerprint sensor board (includes cable and gasket)
L56446-001
(10)
Card reader board (includes cable)
L56452-001
(11)
NFC interface board (includes cable)
L59058-001
(12)
System board (includes processor, a graphics subsystem with UMA memory, and replacement thermal material):
Equipped with an Intel Core i7-8565U processor and the Windows 10 operating system
L65219-601
Equipped with an Intel Core i7-8565U processor and a non-Windows 10 operating system
L65219-001
Equipped with an Intel Core i5-8265U processor and the Windows 10 operating system
L65218-601
Equipped with an Intel Core i5-8265U processor and a non-Windows 10 operating system
L65218-001
(13)
Heat sink (includes replacement thermal material)
L56445-001
(14)
Fan
L56444-001
(15)
Solid-state drive shield (included in the Bracket Kit, spare part number L56447-001)
(16)
Solid-state drive (M.2):
1 TB, PCIe, NVMe, TLC
L60457-001
512 GB, PCIe, NVMe
L64978-001
256 GB, PCIe, NVMe, TLC
L60458-001
256 GB, PCIe, NVMe
L60459-001
256 GB, SATA-3, TLC, Opal 2
L60464-001
(17)
Intel 9560 ac 2×2 + Bluetooth 5 MU-MIMO M.2 2230 non-vPro 160-MHz MIPI + BRI WW WLAN module
L22634-005
(18)
Memory module shield (included in the Bracket Kit, L56447-001)
(19)
Memory module (DDR4-2666, 1.2-V):
16 GB
937438-852
8 GB
937236-852
(20)
Battery (4-cell, 53-Whr, 3.45-Ahr, includes cable)
L34449-002
(21)
Speakers (includes cable)
L56456-001
(22)
Bottom cover
L65215-001
Miscellaneous parts
Miscellaneous parts and their descriptions
Component
Spare part number
65 W AC adapter, USB Type-C, (non-PFC, 1.8-m)
L32392-001
Duck head adapter for use in the People’s Republic of China (premium, black, C5NS, with sticker)
L50818-005
Power cord for use in the People’s Republic of China (C5 connector, 1.8 m, premium, with FDH sticker):
L45270-001
Screw Kit
L56455-001
Cable Kit
Figure : Identifying the Cable Kit components
Cable Kit part number, components, and their descriptions
Item
Component
Spare part number
Cable Kit, includes the following cables:
L56450-001
(1)
Power button board cable
(2)
Touchpad cable
(3)
NFC module cable
(4)
NFC antenna cable
(5)
Card reader cable
Plastics Kit
Figure : Identifying the Plastics Kit components
Plastics Kit part number, components, and their descriptions
Item
Component
Spare part number
Plastics Kit, includes the following parts:
L56454-001
(1)
Fingerprint sensor insert
(2)
Smart card reader insert
(3)
I/O bracket
Bracket Kit
Figure : Identifying the Bracket Kit components
Bracket Kit part number, components, and their descriptions
Item
Component
Spare part number
Bracket Kit, includes the following parts:
L56447-001
(1)
USB bracket
(2)
Fingerprint sensor bracket
(3)
Solid-state drive EMI shield
(4)
Memory module EMI shield
