    Fix Windows 10 Update Issues
HP Z2 Mini G4 Workstation - Components
Standard configuration features
Features may vary depending on the model.
Figure : HP Z2 Mini G4 Workstation
HP Z2 Mini G4 Workstations offer models with Intel® Xeon® E 21xx processors and Intel 8th-Gen Core-i™ series processors.
Models with Intel Core-i series processors support Windows 10 only.
Front
Figure : HP Z2 Mini G4 Workstation front panel components
Item
Icon
Component
1
Power button
2
Power on LED
Left
Figure : HP Z2 Mini G4 Workstation left panel components
Item
Icon
Component
Item
Icon
Component
1
USB SuperSpeed port
3
USB Type-C SuperSpeed Plus port with HP Sleep and Charge
2
USB SuperSpeed port with HP Sleep and Charge
4
Audio-out (headphone)/Audio-in (microphone) combo jack
Rear
Performance model
Figure : HP Z2 Mini G4 Workstation rear panel components
Item
Icon
Component
Item
Icon
Component
1
Cable lock slot
6
Power cord connector
2
Access panel release
7
DisplayPort 1.2 connectors (3)
Driven by NVIDIA GPU
3
Serial port (optional)
8
USB Type-C SuperSpeed port
4
RJ-45 (network) jack
9
Flexible I/O module
5
Hard drive activity light
On: The computer is on.
Blinking white: The hard drive is being accessed.
10
USB SuperSpeed ports (2)
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available when contacting support for assistance.
Figure : Identifying the computer serial number location
