HP Pavilion - 15-cs3088tx Product Specifications
8VZ14PA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
4 GB DDR4-2666 SDRAM (1 x 4 GB)
1 TB 5400 rpm SATA
15.6" diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
Intel® Wireless-AC 9461 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 5 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
36.16 x 24.56 x 1.79 cm
Starting at 1.85 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP Audio Switch; HP CoolSense; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Privacy Settings; HP BIOS Recovery
Pre-installed software
iQiyi; B&O Audio
