HP ENVY - 13-aq0012nw Product Specifications
8PK94EA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2400 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 620
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal FHD IPS micro-edge WLED-backlit edge-to-edge glass with HP Sure View Integrated Privacy Screen (1920 x 1080)
1 microSD media card reader
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 headphone/microphone combo
30.7 x 21.15 x 1.47 cm
1.28 kg
65 W AC power adapter
4-cell, 53 Wh Li-ion polymer
Battery life mixed usage
Up to 11 hours and 30 minutes
B&O, quad speakers, HP Audio Boost, HP Far-field Cortana support
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix (30-day free trial offer)
