    Apache Log4j Update
HP Pavilion x360 14-dh0019np Product Specifications
8KL78EA
Intel® Pentium® Gold 5405U (2.3 GHz base frequency, 2 MB cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 610
128 GB M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal HD SVA micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo;
32.4 x 22.29 x 2.05 cm
1.59 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 9 hours and 15 minutes
Pre-installed software
Netflix
