    Fix HP Printer issue on macOS
HP Spectre x360 - 15-df1018tx Product Specifications
8GB08PA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (onboard)
512 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal 4K IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass with Corning® Gorilla® Glass NBT™, 340 nits, 72% NTSC (3840 x 2160)
Intel® Wi-Fi 6 AX 200 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 AC smart pin; 2x Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DP 1.4, HP Sleep and Charge); 1x USB 3.1 Gen 2 Type-A (HP Sleep and Charge); 1 HDMI; 1 headphone/microphone combo
36.12 x 25 x 1.93 cm
Starting at 2.09 kg
135 W Smart AC power adapter
6-cell, 84 Wh Li-ion polymer
Bang & Olufsen, quad speakers, HP Audio Boost
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
Alexa; iQiyi
