    Fix HP Printer issue on macOS
HP Notebook - 14s-dk0076au Product Specifications
6XA61PA
AMD Ryzen™ 5 3500U with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (2 x 4 GB)
Video graphics
AMD Radeon™ Vega 8 Graphics
512 GB PCIe® NVMe™ M.2 SSD
14" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 USB 3.1 Type-C™ (Data transfer only, 5 Gb/s signaling rate); 1 AC smart pin; 2 USB 3.1 Gen 1 Type-A (Data Transfer Only)
32.4 x 22.59 x 1.99 cm
Starting at 1.47 kg
45 W AC power adapter
3-cell, 45 Wh Li-ion polymer
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Documentation; HP JumpStart; HP Audio Switch; HP Support Assistant
