HP 24y 23.8-inch Display Product Specifications
1PX48AA
Display size
60.45 cm (23.8")
Display type
IPS w/LED backlight
Panel active area(inches)
20.74 x 11.67 in
Panel active area(cms)
52.7 x 29.64 cm
Brightness
250 cd/m²
Pixel Pitch
0.274 mm
Input connector
1 VGA; 1 DVI-D; 1HDMI
Viewing angle
178° horizontal; 178° vertical
Scan range (horizontal)
Up to 80 kHz
Scan range (vertical)
Up to 60 Hz
Recommended resolution
1920 x 1080 (FHD)
Aspect ratio
16:09
Static contrast ratio;Dynamic contrast ratio
1000:1 static; 10000000:1 dynamic
Response time
8 ms gray to gray
Tilt
Tilt: -5 to +20°
Input voltage: 100-240 VAC at 50 - 60 Hz; Power consumption: 25W maximum, 22W typical; Standby mode: 0.5W
Dimensions
54.66 x 20.99 x 40.51 cm (with stand); 54.66 x 4.47x 32.1 cm (without stand)
3.65 kg (with stand); 3.3 kg (without stand)
