HP t640 Thin Client Specifications
Product image
Operating systems
Specification
Preinstalled
HP ThinPro, including HP Smart Zero Core
Windows 10 IoT Enterprise LTSC 2019
Processors
Specification
AMD Ryzen R1505G
2.4 GHz base frequency, up to 3.3 GHz burst frequency
2 cores and 4 threads
4 MB L3 cache
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of higher performance.
Graphics
Specification
Supported displays
3
Video outputs
Standard
(3) DisplayPort 1.2
Optional
(1) DisplayPort over USB Type-C with USB Power Delivery
(1) VGA analog output
(1) HDMI digital output
Adding and optional output does not increase the number of displays supported.
System should be configured with dual channel memory (two SODIMMs) configurations for optimal display resolution performance.
Memory
Specification
Standard
DDR4 dual channel SDRAM
Data transfer rate
Up to 2400 MT/s
Peak transfer rate
19200 MB/s
Capacities offered
4, 8, 16 and 32 GB
System should be configured with dual channel memory (two SODIMMs) configurations for optimal system performance.
Storage
Specification
Type
NAND flash memory; non-volatile
Number of sockets
(1) M.2
Capacities offered
16 GB M.2 eMMC flash module
32 GB M.2 eMMC flash module
64 GB M.2 eMMC flash module
128 GB M.2 SATA flash module
256 GB M.2 NVMe flash module
512 GB M.2 NVMe flash module
Audio/multimedia
Specification
Audio CODECs
MP3
AAC Stereo
HE AAC
Includes hardware acceleration support
Audio subsystem
Internal amplified speaker system for basic audio playback
(1) 3.5 mm combo headset/headphone/analog microphone audio jack (front access)
(1) 3.5 mm combo line-out/ line-in socket (rear access)
Video
MPEG-4 part 2 (DivX, Xvid)
MPEG-4 part 10 (H.264, AVC), Advanced Video Coding (AVC) (H.264 encode)
MPEG-H part 2, High Efficiency Video Coding (HEVC) (H.265 decode)
WMV 7/8/9 VC-1 & ASF Demuxer
Input/output ports
Specification
USB ports
Front
(1) USB 3.1 Gen 1 Type-A port
(1) USB 3.1 Gen 2 Type-A por
(1) USB 3.1 Gen 2 Type-C port
Rear
(1) USB 2.0 Type-A port
(1) USB 2.0 Type-A port (designated for Power-on from Keyboard if equipped)
(2) USB 3.1 Gen 1 Type-A ports
(2) USB 3.1 Gen 1 Type-A ports (optional)
Optional port (configuration options)
Blank (no optional configured port)
DisplayPort over USB-C with USB Power Delivery
HDMI digital video output
VGA analog video output
External Wi-Fi antenna connector (requires Wi-Fi adapter option)
Fiber Optic NIC connectors; SC or LC connector (requires Fiber Optic NIC option)
Serial port with configurable power
Dual serial ports (includes cable adapter)
Video outputs
Standard
(3) DisplayPort 1.2 digital outputs
Optional
Other
Standard
(1) RJ-45 Gigabit Ethernet interface
(1) 3.5 mm headphone-microphone combo jack (front access)
(1) 3.5 mm audio jack (rear)
Optional
(1) Serial port with configurable power
(2) Serial ports enabled with an included cable adapter
Networking/communication
Specification
Wi-Fi (WLAN)
Intel Wireless-AC 9260 Wi-Fi and Bluetooth combo
(2x2) 802.11ac Wi-Fi and Bluetooth 5
Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited.
Wired LAN
Realtek RTL8111EPH-CG Gigabit Ethernet (GbE) Controller with support for DASH out-of-band remote management
Fiber Optic networking
Allied Telesis AT-27M2/SC Fiber Fast Ethernet M.2 Adapter
Allied Telesis AT-29M2/SC or LC Fiber Gigabit M.2 Adapter
Supported host environments
Host environment
Protocol
Compatibility
Microsoft Remote Desktop Services
Remote FX (RFX) and RDP
HP ThinPro and Windows 10 IoT Enterprise 2019
Citrix
ICA and HDX
VMware Horizon
RDP, PCoIP, and Blast Extreme
Supported protocol clients
Protocol clients
Compatibility
Citrix Workspace app
VMware Horizon View client
Microsoft Remote Desktop Client
Free Remote Desktop Client
HP ThinPro
HP Remote Graphics Software (RGS)
HP ThinPro via add-on
Turbosoft TTerm for Linux Terminal emulation Software
Turbosoft TTWin Terminal emulation software
Windows 10 IoT Enterprise 2019 via add-on
Software/security
Functionality
Application
Compatibility
Browser support
Mozilla Firefox
HP ThinPro
Internet Explorer
Management tools
HP Device Manager
HP ThinUpdate
HP Easy Tools
HP ThinPro
HP Smart Zero Client Services
HP ThinPro
Microsoft SCCM/EDM agent
HP USB Port Manager
Security
SmartCard
Logon Manager
Read-only operating system
802.1x
Microsoft Firewall
HP Write Manager
Microsoft Unified Write Filter
Audio/Video CODEC
MP3
WMA stereo
AAC stereo and HE AAC
HP ThinPro
Microsoft AC3 encoder
MPEG-1
MPEG-4 part 2 (H.263)
MPEG-4 part 10 (H.264 AVC)
WMV 7/8/9/ VC-1 & ASF Demuxer
Software performance and support might vary.
Power
Specification
Power supply
45 W non-PFC Smart external power adapter
Worldwide auto-sensing 100 to 240 VAC, 50 to 60 Hz
Energy saving automatic power-down
Surge tolerant
Cable
1.83 m (6.0 ft) output cable
Physical specifications
Specification
Dimensions (W x D x H) (vertical orientation)
Without stand
35.0 x 196.0 x 196.0 mm (1.38 x 7.72 x 7.72 in)
All measurements are approximate.
System weight
1001.5 g (2.21 lb)
Shipping weight
2885 g (6.36 lb)
The addition of optional modules increases the weight.
