HP Desktop PCs - motherboard specifications, Moria2
Moria2 motherboard
Motherboard description
HP name: Moria2
SSID: 84FE
Form Factor
Micro ATX, channel board exchangeable
Dimensions: 24.0 x 24.0 cm (9.45 x 9.45 in)
B450
Processor upgrade information
TDP: up to 65 W
Socket type: AM4
Motherboard supports the following processor upgrades:
Processor
TDP
AMD Ryzen 5 3500 3.4 GHz Base frequency, up to 4.1 GHz maximum boost frequency, Hexa core (Matisse)
65 W
AMD Ryzen 5 3600 3.6 GHz Base frequency, up to 4.2 GHz maximum boost frequency, Hexa core (Matisse)
65 W
AMD Ryzen 7 3700X 3.6 GHz Base frequency, up to 4.4 GHz maximum boost frequency, Octa core (Matisse)
65 W
Memory upgrade information
Dual channel (1 DIMM per channel) memory architecture
Two DDR4 UDIMM (288-pin) sockets
Supports PC4-21300 (DDR4-2666)
Supports 8 GB and 16 GB DDR4 UDIMMs
Supports up to 4 GB on 32-bit systems
32-bit systems cannot address a full 4.0 GB of memory.
Supports up to 32 GB (unbuffered) with 16 GB DIMMs on 64-bit computers.
Maximum memory shown reflects the capability of the hardware and can be limited further in the operating system.
Video
No integrated graphics
The Moria2 motherboard does not support integrated graphics.
Audio
Integrated audio
Audio Codec: ALC3866-CG
High Definition (Azalia) 5.1 channel audio support
The motherboard supports 5.1 surround sound. If the computer does not have the required audio jacks for a 5.1 configuration, additional hardware is required to use 5.1 surround sound.
Audio jack presence detection
An internal speaker is not included with integrated audio. External speakers or headphones are required to hear sound.
Integrated audio is not available if a sound card is installed.
Network
LAN: 1000BASE-T
Technology: Realtek RTL8118 ASH-CG
Data transfer speeds: up to 10/100/1000 Mb/s
Transmission standards: 1000BASE-T Ethernet
One PCIe Gen 3 x16 socket (for discrete graphic card)
One M.2 socket 1, key A
One M.2 socket 3, key M for SSD (PCIe x4)
I/O ports and jumpers
Back I/O ports
The configuration might vary depending on your model (for example, if a dedicated graphics card is included). Any modifications or upgrades might change the configuration, port accessibility, and port functionality.
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
