OMEN X by HP 2S 15-dg0035tx Product Specifications
8BE00PA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
32 GB DDR4-2666 SDRAM (2 x 16 GB)
Video graphics
NVIDIA® GeForce RTX™ 2080 (8 GB GDDR6 dedicated)
Two 512 GB PCIe® NVMe™ TLC M.2 SSD with Raid 0 configured
15.6" diagonal FHD 144 Hz IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Intel® Wireless-AC 9560 Wi-Fi 5 (2x2) and Bluetooth® 5 Combo, non-vPro™
2 M.2 PCIe® x4
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 HDMI
36.21 x 26.17 x 2 cm
Starting at 2.38 kg
230 W Smart AC power adapter
6-cell, 72 Wh Li-ion polymer
HP Wide Vision FHD Camera with integrated dual array digital microphone
Bang & Olufsen; dual speakers; HP Audio Boost; Omen Audio Control Support DTS:X® Ultra
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP PC Hardware Diagnostics Windows; HP BIOS Recovery
Pre-installed software
iQiyi
