7QM24UA
HP Notebook - 15-db1004cy
AMD Ryzen™ 5 3500U with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
Video graphics
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
15.6" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 AC smart pin; 1 USB 2.0 Type-A (Data Transfer Only)
37.6 x 24.6 x 2.25 cm
1.97 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 45 minutes
Video Playback Battery life
Up to 6 hours and 45 minutes
HP TrueVision HD Camera with integrated digital microphone
Stereo speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Notebook - 15-db1004cy Product Specifications
HP Audio Switch; HP Games by WildTangent; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP BIOS Protection
Pre-installed software
Netflix; DVD Playback
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
