HP Gaming Pavilion - 17-cd0054ur Product Specifications
7RX95EA
Intel® Core™ i5-9300H (2.4 GHz base frequency, up to 4.1 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 1050 (3 GB GDDR5 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
17.3" diagonal FHD IPS anti-glare micro-edge WLED (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ (10 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 HDMI; 1 AC smart pin; 1 RJ-45; 1 headphone/microphone combo
40.5 x 28.2 x 2.5 cm
2.74 kg
135 W AC power adapter
3-cell, 52.5 Wh Li-ion polymer
Battery life mixed usage
Up to 8 hours and 45 minutes
Video Playback Battery life
Up to 7 hours
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
