    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP Pavilion 15-cs1040ur Product Specifications
6AV35EA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
12 GB DDR4-2400 SDRAM (1 x 4 GB, 1 x 8 GB)
256 GB PCIe® NVMe™ M.2 SSD
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB Type-C™ 3.1 Gen 1 (Data transfer only, up to 5Gb/s); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 1.4; 1 RJ-45; 1 headphone/microphone combo
36.16 x 24.16 x 1.79 cm
1.85 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 16 hours and 45 minutes
Video Playback Battery life
Up to 15 hours
FreeDOS 1.2
