    Apache Log4j Update
HP Gaming Pavilion - 17-cd0020ur Product Specifications
7GL79EA
Intel® Core™ i5 9300H (2.4 GHz base frequency, up to 4.1 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 7200 rpm SATA
Optical drive
Optical drive not included
43.9 cm (17.3") diagonal Full HD display
1 USB 3.1 Gen 2 Type-C™ (10 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 HDMI; 1 AC smart pin; 1 RJ-45; 1 headphone/microphone combo
40.5 x 28.2 x 2.5 cm
2.77 kg
150 W AC power adapter
3-cell, 52.5 Wh Li-ion polymer
FreeDOS 1.2
