    Apache Log4j Update
HP Color LaserJet Pro M454, MFP M479 - Load paper to Tray 1
The following information describes how to load paper into Tray 1.
Load Paper Tray 1 (multipurpose tray)
Follow these steps to load paper in Tray 1.
This tray holds up to 50 sheets of 75 g/m2 paper.
To avoid jams, never add or remove paper from Tray 1 during printing.
  1. Open Tray 1 by grasping the handles on the left and right side of the tray and pulling down.
    Figure : Open tray 1
  2. Slide out the tray extension.
    Figure : Slide out tray extension
  3. Press down on the tab on the right paper guide, and then spread the paper guides to the correct size.
    Figure : Open paper guides
  4. Load the paper into the tray. Make sure that the paper fits under the tabs and below the maximum height indicators.
    For information on how to orient the paper, see Tray 1 paper orientation.
    Figure : Load paper
  5. At the computer, begin the printing process from the software application. Make sure that the driver is set to the correct paper type and size for the paper being printed from the tray.
When using paper that requires a specific orientation, load it according to the information in the following table.
Paper type
Output
How to load paper
Letterhead or preprinted
1-sided printing
Face-up
Top edge leading into the printer
Figure : Paper orientation face-up
2-sided printing
Face-down
Top edge away from the printer
Figure : Paper orientation face-down
Pre-punched
1-sided or 2-sided printing
Face-up
Holes toward the left side of the printer
Figure : Paper orientation with holes on the left side
