HP Notebook - 15s-du0069tu Product Specifications
7EW21PA
Intel® Core™ i3-7020U (2.3 GHz base frequency, 3 MB cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
Intel® HD Graphics 620
128 GB M.2 SSD
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek 802.11a/b/g/n/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.74 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
FreeDOS 2.0
