HP Neverstop Laser MFP 1200 - Er/01 Displays, Printer Does Not Pick Paper
This document is for HP Neverstop Laser MFP 1200a, 1200n, 1200nw, 1200w, 1201n, 1202nw, and 1202w printers.
During a print or copy job, the printer does not pick up paper from the input tray. One of the following error messages might also display.
  • The Attention light and Paper light blink, and the control panel character display alternates between Er and 01.
  • An Out of Paper message displays in the printer software.
Step 1: Check the paper, and then reload it
Paper feed issues might result from using ripped, dusty, curled, wrinkled, or bent paper. The quality of the paper can also make a difference. Follow these guidelines to help avoid the issue.
  • Use only good quality paper that meets printer specifications.
  • Store all paper in a dry, cool place. Paper feed issues occur more often in humid climates.
  • Wait for the printer to complete a job or the Attention light and Paper light to blink before you reload the paper.
Remove the paper from the input tray, check and flex the paper, and then reinsert it.
  1. Remove the input tray cover.
    Removing the input tray cover
  2. Slide out the paper guides as far as possible.
    Sliding out the paper guides
  3. Remove the stack of paper or envelopes from the input tray.
    If there is any jammed paper, pull it straight away from the printer with both hands. Pulling jammed paper at an angle can damage the printer.
    Removing jammed paper from the input tray area
  4. Remove any severely bent, wrinkled, or torn paper from the stack.
  5. Holding the paper stack in both hands, flex the stack in multiple directions to loosen stuck paper sheets.
    Flexing the paper stack
  6. Reinsert the stack of paper or envelopes into the input tray.
    Do not insert more than 150 sheets of paper at one time.
    Loading paper
  7. Slide the paper guides in until they touch the edges of the paper.
    Sliding the paper guides in
  8. Replace the input tray cover.
    Replacing the input tray cover
Try to print. If the issue persists, continue to the next step.
Step 2: Check the paper settings
Make sure your paper settings match the paper in the input tray.
Step 3: Check and clean inside the printer
The printer can gather dust and paper pieces. Check for paper jams, and then carefully clean the paper path rollers with a lint-free cloth dampened with warm water.
  1. Turn off the printer, unplug the power cord from the back of the printer, and then wait for the printer to cool.
      warning:
    You must disconnect the power cord before reaching inside the printer to avoid risk of injuries or electric shock.
  2. Remove the input tray cover.
  3. Remove any paper from the input tray.
  4. Remove any paper from the output tray.
  5. Lift the scanner, and then open the top cover.
    Lifting the scanner and top cover
  6. Using the handle, pull the imaging drum up and out to remove it, and then carefully set it aside.
    To prevent damage, do not expose the imaging drum to light or touch the green roller. Cover it with a piece of paper.
    Removing the used imaging drum
  7. Check for jammed paper and debris, and then remove it.
    Carefully pull jammed paper straight away from the printer with both hands. Pulling jammed paper at an angle can damage the printer.
    Removing jammed paper from the imaging drum area
  8. Lightly dampen a lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  9. Clean the pickup roller, applying a moderate amount of pressure.
    Location of the pickup roller inside the printer
  10. Allow the pickup roller to dry completely (approximately 10 minutes).
  11. Hold the imaging drum by the handle, align it with the tracks, and then insert it into the printer.
    Reinstalling the imaging drum
  12. Close the top cover, and then lower the scanner.
    Closing the top cover and lowering the scanner
Step 4: Reset the printer
Sometimes an error persists even though there is no paper feed issue. Reset the printer, and then try to print.
  1. With the printer turned on, disconnect the power cord from the printer.
  2. Unplug the power cord from the power source.
  3. Wait 60 seconds.
  4. Reconnect the power cord to a wall outlet and to the printer.
    HP recommends plugging the printer directly into a wall outlet.
Step 5: Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
