HP LaserJet Enterprise M507 - Printer views
Identify certain parts of the printer and the control panel.
Printer front view
Use the diagram to locate important components on the printer.
    Figure : Printer front view
  1. Top cover (access to the toner cartridge)
  2. Easy-access USB portInsert a USB flash drive for printing without a computer or to update the printer firmware.An administrator must enable this port before use.
  3. Output bin
  4. On/off button
  5. 2.7-in QVGA LCD color display with 24-key pad (n and dn models)
  6. Hardware integration pocket for connecting accessory and third-party devicesTo use the hardware integration pocket (HIP), install the HP internal USB ports accessory (B5L28A). The USB port inside the HIP is not functional otherwise.
  7. Formatter cover
  8. Tray 2
  9. Model name
  10. Tray 1
  11. Control panel with color touchscreen display (x models only)
  12. 1 x 550-sheet paper feeder, Tray 3 (included with the x model, optional for the other models)Each printer model accepts up to three optional 1 x 550-sheet feeders (Trays 3, 4, and 5). Tray 3 is included with the x model.
Printer back view
    Figure : Printer rear view
  1. Rear door (access for clearing jams)
  2. Serial number and product number label
  3. Top-cover-release button
  4. Dust cover for Tray 2 (flips up when legal-size paper is loaded)
  5. Power connection
  6. Formatter (contains the interface ports)
Interface ports
Use the diagram to identify the printer interface ports.
    Figure : Interface ports
  1. Slot for a cable-type security lock
  2. Local area network (LAN) Ethernet 10/100/1000 network port
  3. Hi-Speed USB 2.0 printing port
  4. USB port for connecting external USB devices (this port might be covered)For easy-access USB printing, use the USB port near the control panel.
Control-panel view (2.7-in QVGA LCD color display with 24-key pad, n and dn models)
Use the 2-line control panel to obtain printer and job status information and to configure the printer.
    Figure : Printer control panel
  1. Reset button
  2. Sign In or Sign Out button
  3. Applications area
  4. Home button
  5. Information button
  6. Help button
  7. Back button
  8. Up arrow button
  9. Message Center button
  10. Left arrow button
  11. OK button
  12. Right arrow button
  13. Start button
  14. Down arrow button
  15. Cancel button
  16. Clear button
  17. Sign In or Sign Out button
  18. Numeric keypad
  19. Home-screen page indicator
Control-panel view (touchscreen, x models only)
Use the touchscreen control panel to obtain printer and job status information and to configure the printer.
Tilt the control panel for easier viewing.
Return to the Home screen at any time by selecting the Home button at the bottom of the printer control panel.
For more information about the printer-control-panel features, go to www.hp.com/support/ljM507. Select Manuals, and then select General reference.
The features that appear on the Home screen can vary, depending on the printer configuration.
  1. Reset button
  3. Information button
  4. Help button
  5. Current time
  6. Applications area
  7. Home-screen page indicator
  8. Home button
How to use the touchscreen control panel
Use the following actions to use the printer touchscreen control panel.
Control panel actions
Action
Example
Touch
Touch an item on the screen to select that item or open that menu. Also, when scrolling through menus, briefly touch the screen to stop the scrolling.
Touch the Settings icon to open the Settings app.
Swipe
Touch the screen and then move your finger horizontally to scroll the screen sideways.
Swipe until the Settings app displays.
Scroll
Touch the screen and then move your finger vertically to scroll the screen up and down. When scrolling through menus, briefly touch the screen to stop the scrolling.
Scroll through the Settings app.
