HP LaserJet Enterprise MFP M528, HP LaserJet Managed MFP E52645 - Supported paper sizes and types
Use the following information to check paper sizes and types that are compatible with your printer. To obtain the best results, select the correct paper size and type in the print driver before printing.
The paper sizes in the following table are supported by your printer. Each paper size is followed by the specific trays and other printer components that are compatible with that paper size.
Paper size
Compatible trays/components
Letter: 215.9 x 279.4 mm
Tray 1, Tray 2, Tray 3, Tray 4, Tray 5, Duplex (auto and manual)
Legal: 215.9 x 355.6 mm
Executive: 184.2 x 266.7 mm
Statement: 139.7 x 215.9 mm
Oficio (8.5 x 13): 215.9 x 330.2 mm
3 x 5: 76.2 x 127 mm
Tray 1
4 x 6: 101.6 x 152.4 mm
Tray 1
5 x 7: 127 x 177.8 mm
5 x 8: 127 x 203.2 mm
16K: 184 x 260 mm
16K: 195 x 270 mm
16K: 197 x 273 mm
A4: 210 x 297 mm
A5: 148 x 210 mm
A6: 105 x 148 mm
RA4: 215 x 305 mm
B5 (JIS): 182 x 257 mm
B6 (JIS): 128 x 182 mm
10 x 15 cm: 101.6 x 152.4 mm
Tray 1
Oficio (216 x 340): 216 x 340 mm
Japanese Postcard: 100 x 148 mm
Tray 1
Japanese Double Postcard: 148 x 200 mm
Envelope #9: 98.4 x 225.4 mm
Tray 1
Envelope #10: 104.8 x 241.3mm
Tray 1
Envelope Monarch: 98.4 x 190.5 mm
Tray 1
Envelope B5: 176 x 250 mm
Tray 1
Envelope C5: 162 x 229 mm
Tray 1
Envelope C6: 114 x 162 mm
Tray 1
Envelope DL: 110 x 220 mm
Tray 1
Custom media sizes: 76.2 x 127 mm to 215.9 x 355.6 mm
Tray 1
Custom media sizes: 105 x 148 mm to 215.9 x 355.6 mm
Supported paper types
The following paper types are compatible with your printer.
  • Plain
  • HP EcoFFICIENT
  • Light 60-74g
  • Intermediate 85-95g
  • Mid-Weight 96-110g
  • Heavy 111-130g
  • Extra Heavy 131-175g
  • Cardstock 176-220g
  • Monochrome Laser Transparency
  • Labels
  • Letterhead
  • Envelope
  • Preprinted
  • Prepunched
  • Colored
  • Bond
  • Recycled
  • Rough
