    Apache Log4j Update
HP Color LaserJet Enterprise M751, HP Color LaserJet Managed E75245 - Load paper to the 2,700-sheet high-capacity input paper trays
The following information describes how to load paper into the high-capacity input (HCI) paper tray. This tray holds up to 2,700 sheets of 75 g/m2 paper.
Do not extend more than one paper tray at a time.
  1. Release the tray latch, and then slide the tray away from the printer to open it.
    Do not open this tray while the printer is printing.
    Figure : Open the tray
  2. Adjust the paper-size guide to the correct position for the paper.
    Figure : Adjust the guides
  3. Load paper into the tray. Check the paper to verify the guides lightly touch the stack, but do not bend it. For information about how to orient the paper, see 2,700-sheet HCI paper tray paper orientation.
    To prevent jams, do not overfill the tray. Be sure that the top of the stack is below the tray full indicator.
    If the tray is not adjusted correctly, an error message might appear during printing or the paper might jam.
    Figure : Load paper
  4. Close the tray.
    Figure : Close the tray
  5. The tray configuration message displays on the printer control panel.
  6. Press the OK button to accept the detected type and size, or select Modify to choose a different paper size or type.
Letterhead or preprinted - Portrait
Duplex mode
Paper size
How to load paper
1-sided printing
A4, Letter
Face-down
Top edge at the back of the tray
Automatic 2-sided printing or with Alternative Letterhead Mode enabled
A4, Letter
Face-up
Letterhead or preprinted - Landscape
Duplex mode
Paper size
How to load paper
1-sided printing
A4, Letter
Face-down
Top edge at the left side of the tray
A4, Letter
Face-up
Top edge at the right side of the tray
Prepunched - Landscape
Duplex mode
Paper size
How to load paper
1-sided printing
A4, Letter
Face-down
Holes at the left side of the tray
A4, Letter
Face-up
Holes at the right side of the tray, with the top of the form to the right side
Use Alternative Letterhead mode
Use the Alternative Letterhead Mode feature to load letterhead or preprinted paper into the tray the same way for all jobs, whether printing to one side of the sheet of paper or to both sides. When using this mode, load paper as for automatic duplex printing.
To use the feature, enable it by using the printer control-panel menus:
  1. From the Home screen on the printer control panel, open the Settings menu.
  2. Open the following menus:
    1. Print
    2. Manage Trays
    3. Alternative Letterhead Mode
  3. Select On, and then press the OK button.
