    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP Gaming Pavilion - 15-cx0010ua Product Specifications
6VQ37EA
Intel® Core™ i5 8300H (2.3 GHz base frequency, up to 4 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
8 GB DDR4-2666 SDRAM (2 x 4 GB)
  • 128 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 7200 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Type-C™ Gen 1 (Data transfer only, up to 5 Gb/s); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 2.0; 1 RJ-45; 1 headphone/microphone combo
36.5 x 25.65 x 2.54 cm
2.4 kg
200 W AC power adapter
4-cell, 70 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
FreeDOS 1.2
