HP LaserJet Managed MFP E72425, E72430, E77422, E77428, E78223, E78228 - 13.B2, 13.A3, 13.A4, 13.A5, 13.A8 jam error in tray 2, tray 3, or in the optional 2 x 520-sheet trays
Use the following procedure to check for paper in all possible jam locations related to tray 2, tray 3, or the optional 2 x 520-sheet trays. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 13.B2.Az Jam in right door
  • 13.B2.D2 Jam in tray 2
  • 13.A3.yz
  • 13.A4.yz
  • 13.A5.yz
  • 13.A8.Az
  • 13.A8.Dz
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam in tray 2, tray 3, or the optional 2 x 520-sheet trays:
The fuser can be hot while the printer is in use. Wait for the fuser to cool before handling it.
The procedure to clear a paper jam in Tray 3, or the optional 2 x 520-sheet trays, is the same as for Tray 2. Only Tray 2 is shown here.
  1. Open the right door.
    Figure : Open the right door
  2. Gently remove any jammed paper from inside the right door.
    Figure : Remove jammed paper from inside the right door
  3. Close the right door.
    Figure : Close the right door
  4. Open the tray.
    Figure : Open the tray
  5. Gently remove any jammed or damaged paper from the tray.
    Figure : Remove jammed paper from the tray
  6. Close the tray. Printing automatically resumes.
    Figure : Close the tray
