    Apache Log4j Update
HP Pavilion - 15-cs2051od Product Specifications
6GS02UA
Intel® Core™ i7 8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
12 GB DDR4-2400 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
256 GB M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 1.4; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only, 5 Gb/s signaling rate); 1 AC smart pin
36.16 x 24.16 x 1.79 cm
1.85 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 11 hours
Video Playback Battery life
Up to 9 hours
B&O, dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP BIOS Protection
Pre-installed software
Netflix
