    Apache Log4j Update
HP Notebook - 15-db0062nr Product Specifications
6MW65UA
AMD A4-9125 Dual-Core (2.3 GHz base frequency, up to 2.6 GHz burst frequency, 1 MB cache)
4 GB DDR4-1866 SDRAM (1 x 4 GB)
Video graphics
  • AMD Radeon™ R3 Graphics
  • Integrated
500 GB 5400 rpm SATA
Optical drive
DVD-Writer
15.6" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45; 1 USB 2.0; 2 USB 3.1 Gen 1 (Data transfer only)
37.6 x 24.6 x 2.25 cm
1.97 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 9 hours
Video Playback Battery life
Up to 6 hours and 30 minutes
HP TrueVision HD Camera with integrated digital microphone
Stereo speakers
HP Audio Switch; HP Games by WildTangent; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP BIOS Protection
Pre-installed software
CyberLink Power Media Player; Netflix
