    Apache Log4j Update
HP ENVY x360 - 15-cp0086nr Product Specifications
5YJ81UA
AMD Ryzen™ 5 2500U Quad-Core (2 GHz base frequency, up to 3.6 GHz burst frequency, 6 MB cache)
12 GB DDR4-2400 SDRAM (1 x 4 GB, 1 x 8 GB)
Video graphics
  • AMD Radeon™ Vega 8 Graphics
  • Integrated
1 TB 7200 rpm SATA
Optical drive
Optical drive not included
15.6" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 USB 3.1 Type-C™ Gen 2 (Data Transfer up to 5 Gb/s, Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 2.0; 1 headphone/microphone combo
35.9 x 24.6 x 1.89 cm
2.04 kg
65 W AC power adapter
3-cell, 52.5 Wh Li-ion
Bang & Olufsen, dual speakers, HP Audio Boost
