    Apache Log4j Update
HP Chromebook - 14-db0041wm Product Specifications
5VR82UA
AMD Dual-Core A4-9120C APU (1.6 GHz base clock, up to 2.4 GHz max boost clock, 1 MB cache)
4 GB DDR4-1866 SDRAM (onboard)
Video graphics
  • AMD Radeon™ R4 Graphics
  • Integrated
32 GB eMMC
Optical drive
Optical drive not included
14" diagonal FHD IPS anti-glare WLED-backlit edge-to-edge glass (1920 x 1080)
Qualcomm® Atheros QCA6174A-5 802.11a/b/g/ac 2x2 Wi-Fi® and Bluetooth® 4.2 Combo
1 microSD media card reader
2 USB 3.1 Gen 1 Type-C™ (Charging, power delivery, video, data); 2 USB 2.0 Gen 1; 1 headphone/microphone combo
33.7 x 22.7 x 1.83 cm
1.54 kg
45 W AC power adapter
2-cell, 47.36 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 30 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
B&O, dual speakers
Chrome OS™
Pre-installed software
Google Play Store
