    Apache Log4j Update
Document ID: c06308089
Version: 1
HP Reverb Virtual Reality Headset - Headset Not Working, Alert in Device Manager After Connecting
Release date : 23-Apr-2019
Last updated : 23-Apr-2019
DESCRIPTION
The headset does not work when initially connected, and the Device Manager shows an alert on HoloLens Sensors under Other devices.
Figure 1. Other devices has alert in Device Manager
Headset not working alert shown in Device Manager
The issue occurs because the driver needs to be installed. The driver will be installed automatically when the computer connects to the internet, but the driver installation can take several minutes to complete.
SCOPE
Accessories:
Operating Systems:
Microsoft Windows 10 RS5 (Version 1809)
RESOLUTION
The headset driver must be installed the first time it is connected:
  1. Make sure both headset cables (USB and DP cables) are connected.
  2. Make sure the computer is connected to the internet.
  3. Allow at least 2 minutes for the driver to update.
  4. Check the device manager; you should now see the headset listed under Mixed Reality devices.
    Figure 2. Headset driver installed, headset appears in Device Manager
    Headset driver installed and headset appears in Device Manager
  5. The headset should work properly now.
Hardware platforms affected : HP Reverb Virtual Reality Headset
Support Communication Cross Reference ID : IA06308089
