Model name
HP Laser MFP 137fnw
4ZB84A
- ${title}
- ${title}
- ${title}
- ${title}
Product Specifications for the HP Laser MFP 137fnw (4ZB84A)
Product naming
What's included and accessories
What's in the box
HP Laser MFP 137fnw Printer; Preinstalled introductory HP Laser Black print cartridges (500 pages); Setup guide; Reference guide; Regulatory statements flyer; Power cord; USB cable; Telecom cable
Connectivity
Ports
Hi-Speed USB 2.0; Fast Ethernet 10/100Base-Tx network port; Wireless 802.11 b/g/n
Wireless capability
Yes, built-in Wi-Fi 802.11b/g/n
Copy
Copier settings
Copies; Original Size; Reduce/Enlarge; Darkness; Original Type; Collation; 2-Up; 4-Up; ID Copy; Adjust Background; Auto Fit Copy
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed (black, normal)
Up to 20 cpm
Copy resolution
Up to 600 x 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.5 B(A) (printing at 20 ppm)
Recommended operating humidity range
20 to 70% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 27°C
Storage temperature range (Celsius)
-20 to 40°C
Environmental specifications
Mercury free
Fax
Fax available
Yes, black & white and color (send only)
Fax features
Permanent fax memory backup, colour faxing, auto fax reduction, auto redialing, delayed sending, fax forwarding, PC fax, secure receive
Fax Resolution Black (best)
Up to 300 x 300 dpi
Fax memory
Up to 400 pages
Telephone handset supported
No
Fax telephone mode supported
Yes
Modem
33.6 kbps
Fax Speed Dials, Maximum Number
Up to 200 numbers
Memory
Memory
128 MB
Maximum Memory
128 MB
Mobile printing capability
Mobile printing services
Apple AirPrint™; Google Cloud Print™; Mobile Apps; Mopria™ Certified; Wi-Fi® Direct Printing
Networking
Network protocols, supported
Via built-in networking solution: TCP/IP, IPv4, IPv6; Print: TCP-IP port 9100 Direct Mode, LPD (raw queue support only), Web Services Printing; Discovery: SLP, Bonjour, Web Services Discovery; IP Config: IPv4 (BootP, DHCP, AutoIP, Manual), IPv6 (Stateless Link-Local and via Router, Stateful via DHCPv6); Management: SNMPv1/v2/v3, HTTP
Paper handling
Input capacity
Up to 150 sheets
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A5 (LEF); B5 (JIS); Oficio; Envelope (DL, C5)
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media types
Plain, Thick, Thin, Cotton, Colour, Preprinted, Recycled, Labels, CardStock, Bond, Archive, Envelope
Media weight supported (metric)
60 to 163 g/m²
Paper handling - ADF
Automatic document feeder capacity
Standard, 40 sheets
Media size (ADF)
B5
Media weight supported, ADF (metric)
60 to 105 g/m²
Physical dimensions
Maximum dimensions (W x D x H, metric)
421.9 x 424 x 308.7 mm
Weight (metric)
8.58 kg
Power
Energy savings feature technology
Power save
Internal (Built-in) power supply
Power supply
220 to 240 VAC, 50/60Hz
Power consumption
300 watts (Active Printing), 38 watts (Ready), 1.9 watts (Sleep), 0.2 watts (Manual Off)
Print cartridges
Number of print cartridges
1 (black)
Replacement cartridges
HP 105A Black Original Laser Toner Cartridge (1,000 pages yield) W1105A; HP 106A Black Original Laser Toner Cartridge (1,000 pages yield) W1106A; HP 107A Black Original Laser Toner Cartridge (1,000 pages yield) W1107A
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 1,200 x 1,200 dpi
Maximum print area (metric)
216 x 356 mm
Monthly duty cycle
Up to 10,000 pages
Print languages
SPL
Printer smart software features
Manual duplex and booklet print, N-up printing, skip blank pages, poster print, watermarks
Regulatory specifications
Safety
IEC 60950-1:2005+A1: 2009+A2 2013 (International); EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 (EU); IEC/EN 60825-1:2014 (Class 1 Laser Product); EN 62479:2010 /IEC 62749:2010; Low Voltage Directive 2006/95/EC with CE Mark (Europe); GS Certificate (Germany, Europe); Compliance with Laser safety standards 21 CFR 1002.10 and 1002.11 except for deviations pursuant to Laser notice No. 50, Dated June 24, 2007; Other safety approvals as required by individual countries
Electromagnetic compatibility
EN 61000-3-2:2014, EN 61000-3-3:2013, EN55024:2010, EN 55032:2012/AC:2013, 47 CFR Part 15, Subpart B I ANSI C63.4-2009, ICES-003 Issue 5, KN32, KN35, GB/T 9254-2008, GB17625.1-2012, CISPR22:2008, CISPR32:2012, CNS 13438, other EMC approvals as required by individual countries
Telecom compliance (fax capability)
EBR21, FCC Prat 68
Scan
Scanner advanced features
Scan to WSD (network support only); Book Scanning; Poster stitching for multiple scan; Text converting; Scan to E-Book; Existing file to E-Book
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 4800 × 4800 dpi
Levels of grayscale
256
Bit depth
8-bit (mono); 16-bit (color)
Maximum flatbed scan size (metric)
216 x 297 mm
Minimum ADF scan size (metric)
145 x 145 mm
Maximum ADF scan size (metric)
216 x 356 mm
Twain version
Version 1.9
Security
Security management
Password-protected network embedded Web server; Enable/disable Network ports; SNMPv1 community password change; SNMPV2/V3; IPSec; Filtering: MAC, IPv4, IPv6
System requirements
Minimum system requirements for Windows
Windows 7 or newer, Intel® Pentium® IV 1 GHz 32/64-bit processor or higher, 1 GB RAM, 16 GB HDD
Compatible Network Operating Systems
Windows®: 7 (32/64-bit), 2008 Server R2, 8 (32/64-bit),10 (32/64-bit), 2012 Server, 2016 Server
Operating system (supported note)
Windows 7 or higher
One-year limited hardware warranty; For more info please visit us at https://www.support.hp.com
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
