    Are you working from home?
HP Notebook - 17-ca0000nf Product Specifications
4GQ43EA
AMD A9-9425 Dual-Core (3.1 GHz base frequency, up to 3.7 GHz burst frequency, 1 MB cache)
AMD Integrated SoC
8 GB DDR4-1866 SDRAM (1 x 8 GB)
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal HD+ SVA anti-glare WLED-backlit (1600 x 900)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
41.48 x 27.22 x 2.45 cm
2.51 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 9 hours
Video Playback Battery life
Up to 8 hours
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
HP Audio Switch; HP JumpStart
Pre-installed software
Netflix
