    Fix Windows 10 Update Issues
    Are you working from home?
Pavilion x360 14-dd0000nf Product Specifications
4XV60EA
Intel® Core™ i3 8130U (2.2 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 620
128 GB M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal HD SVA micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (5 Gb/s signaling rate); 2 USB 3.1 Gen 1 (Data Transfer Only, 5 Gb/s signaling rate); 1 HDMI; 1 headphone/microphone combo
1.59 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 30 minutes
Video Playback Battery life
Up to 9 hours
Windows 10 Home in S mode
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
