    Are you working from home?
HP ENVY x360 - 13-ag0998nk Product Specifications
4XZ74EA
AMD Ryzen™ 3 2300U (2 GHz base frequency, up to 3.4 GHz burst frequency, 6 MB cache, 4 cores)
AMD Integrated SoC
4 GB DDR4-2400 SDRAM (onboard)
Video graphics
AMD Radeon™ Vega 6 Graphics
128 GB M.2 SSD
Optical drive
Optical drive not included
33.8 cm (13.3") diagonal FHD IPS micro-edge WLED-backlit touch screen with Corning® Gorilla® Glass NBT™ (1920 x 1080)
Realtek 802.11b/g/n/a/ac (2x2) and Bluetooth® 4.2 combo
1 microSD media card reader
1 USB Type-C™ 3.1 Gen 1 (Data Transfer up to 5 Gb/s, Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 headphone/microphone combo
30.67 x 21.46 x 1.49 cm
1.3 kg
65 W AC power adapter
4-cell, 53.2 Wh Li-ion
Battery life mixed usage
Up to 11 hours
Video Playback Battery life
Up to 7 hours and 30 minutes
HP Wide Vision HD IR Camera with integrated dual array digital microphone
Bang & Olufsen, quad speakers, HP Audio Boost
HP Audio Switch; HP JumpStart
Pre-installed software
Netflix
