    Fix Windows 10 Update Issues
HP 27ec 27-inch Display Product Specifications
Panel
X3W26AA
Display panel type
IPS w/LED backlight
68.58 cm (27")
Panel active area (W x H)
23.53 x 13.24 in
Resolution
FHD (1920 x 1080 @ 60 Hz)
Aspect ratio
16:9
Viewing angle (typical)
178° horizontal
Brightness (typical)
250 cd/m²
Contrast ratio (typical)
1000:1 static; 10000000:1 dynamic
Response times
7 ms gray to gray
Pixel pitch
0.311 mm
Display features
In plane switching; Language selection; LED Backlights; On-screen controls; Plug and Play; User programmable; Low Haze
Onscreen controls
User controls
Menu; OK; Minus ("-")/Information; Plus ("+") /Input; Auto; QV; Exit; Power; Brightness; Color Control; Image Control; Input Contro; Power Control; Management; Language; Information
Resolutions supported
Signal interface/performance
1920 x 1080 @ 60 Hz (Full HD)
Video/other inputs/cables
Interface
HDMI; VGA
Display Input Type
1 VGA; 2 HDMI 2.0 (with HDCP support)
Ergonomics
Tilt and swivel angle
Tilt: -5 to +25°
Physical security
Security lock-ready (lock is sold separately)
Power
Input voltage
100-240 VAC at 50 - 60 Hz;
Power consumption
29 W (maximum), 23 W (typical), 0.3 W (standby); 29 W (maximum), 24 W (typical), 0.3 W (standby)
Physical specifications
Dimensions (W x D x H)
62.1 x 19.45 x 45.56 cm (with stand); 62.1 x 3.56 x 37.16 cm (without stand)
24.45 x 7.66 x 17.94 in (with stand); 24.45 x 1.40 x 14.63 in (without stand)
3.79 kg (with stand); 3.39 kg (without stand)
What's in the box
What's in the box
AC power cable; Power adapter; VGA cable (selected SKUs); HDMI cable (selected SKUs); CD (includes user guide, warranty, drivers); Quick Setup Poster; Telephone Card; HP Display Assistant
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% RH
Environmental
Mercury-free LED backlighting; Arsenic-Free Display Glass; Low Halogen
Certifications and compliances
CB; CE; TUV-BAUART; ISO 9241-307; CSA; CSA-NRTL; FCC;M ICES; VCCI; CCC; China CEL; BSMI; KCC; KC; E-standby; EUP Lot 6; EUP Lot 26; GEMS; MEPS; (HP)UKRAINIA; HRN N N0.201; EAC; IEC60950:1999; IS 1121; SASO; SABS IEC 60950-1; PSB; ISC; RCM
