    Fix Windows 10 Update Issues
HP P204 19.5-inch Monitor Product Specifications
Panel
5RD65AA
Display panel type
IPS with LED backlight
19.5"
Panel active area (W x H)
43.2 × 23.97 cm
Resolution
HD+ (1600 x 900 @ 60 Hz)
Aspect ratio
16:9
Viewing angle (typical)
160° vertical; 170° horizontal
Brightness (typical)
250 cd/m²
Contrast ratio (typical)
1000:1 static; 10000000:1 dynamic
Response times
5 ms gray to gray
Pixel pitch
0.27 mm
Display features
Anti-glare; LED backlights
Onscreen controls
User controls
Brightness; Color control; Energy saving; Exit; Image control; Information; Management; Menu; PIP control; Input control
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 800; 1366 x 768; 640 x 480; 720 x 400; 800 x 600
Video/other inputs/cables
Interface
HDMI; DVI; VGA
Display Input Type
1 DisplayPort™ 1.2 in (with HDCP support); 1 HDMI 1.4 (with HDCP support); 1 VGA
Ergonomics
Tilt and swivel angle
Tilt: -5 to +25°
VESA mount
VESA mount compatible
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
18 W (maximum), 15 W (typical), 0.3 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
46.26 x 19 x 35.36 cm
Dimensions (W x D x H)
46.26 x 4.87 x 27.87 cm
18.21 x 1.92 x 10.97 in
Product dimensions with stand (W x D x H)
18.21 x 7.48 x 13.92 in
2.84 kg
What's in the box
What's in the box
AC power cord; DisplayPort™ cable; Documentation; HDMI cable; VGA cable
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% non-condensing
Environmental
Arsenic-free display glass; Low halogen; Mercury-free display backlights; TCO Certified
Certifications and compliances
Australian-New Zealand MEPS; BIS; BSMI; CB; CCC; CEL; cTUVus; EAC; Energy Star; ErP; FCC; HSMI; ICES; KC; KCC; Mexico CoC; MSIP; PSB; RCM; TCO Certified; VCCI; Vietnam MEPS; WEEE; ISC; South Africa Energy; ISO 9001; TUS-GS; eStandby; EC1062; S-mark
