HP Pavilion 13-an0067tu Product Specifications
6TK73PA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
8 GB DDR4-2400 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 620
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Intel® Wireless-AC 9461 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 5 Combo
1 USB Type-C™ 3.1 Gen 2 (Data 10 Gb/s signaling rate); 2 USB 3.1 Gen 1 (Data Transfer Only); 1 HDMI 1.4; 1 headphone/microphone combo
31.1 x 21.1x 1.54 cm
1.3 kg
45 W AC power adapter
2-cell, 37.7 Wh Li-ion
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
