HP Pavilion x360 14-dh0003tu Product Specifications
6QK66PA
Intel® Pentium® Silver N5000 (1.1 GHz base frequency, up to 2.7 GHz burst frequency, 4 MB cache, 4 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 605
128 GB M.2 SSD
14" diagonal FHD IPS anti-glare WLED-backlit touch screen (1920 x 1080)
Realtek 802.11 a/b/g/n/ac (1x1) and Bluetooth® 4.2 Combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo;
32.4 x 22.29 x 1.97 cm
Starting at 1.59 kg
65 W EM AC power adapter
3-cell, 41 Wh Li-ion
HP Audio Switch; HP Cool Control; HP JumpStart; HP Documentation; HP Support Assistant; HP Connection Optimizer; HP Privacy Settings
