- ${title}
- ${title}
- ${title}
- ${title}
HP EliteBook x360 830 G5 Notebook PC Specifications
Product image
Operating systems
Specification
Preinstalled
Windows 10 Pro 641
Windows 10 Pro (National Academic only) 642
Windows 10 Home 641
Windows 10 Home Single Language 641
FreeDOS 1.2
note:1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.2Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i3-8130U Processor
2.2 GHz base frequency, up to 3.4 GHz burst frequency
4 MB cache and 2 cores
Intel UHD Graphics 620
Intel Core i5-8250U Processor
1.6 GHz base frequency, up to 3.4 GHz burst frequency
6 MB cache and 4 cores
Intel Core i5-8350U vPro Processor
1.7 GHz base frequency, up to 3.6 GHz burst frequency
Intel Core i7-8550U Processor
1.8 GHz base frequency, up to 4.0 GHz burst frequency
8 MB cache and 4 cores
Intel Core i7-8650U vPro Processor
1.9 GHz base frequency, up to 4.2 GHz burst frequency
Integrated with processor
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Graphics
Specification
Integrated
note: |
Specification
Touch (Corning Gorilla Glass 5)
33.80 cm (13.30 in) diagonal FHD IPS BrightView LED-backlit touch screen with Corning Gorilla Glass 5, 220 cd/m2, 45% with HD camera (1920 x 1080)
33.80 cm (13.30 in) diagonal FHD IPS BrightView LED-backlit touch screen with Corning Gorilla Glass 5, 220 cd/m2, 45% with HD camera WWAN (1920 x 1080)
33.80 cm (13.30 in) diagonal FHD IPS BrightView LED-backlit touch screen with Corning Gorilla Glass 5, 400 cd/m2, 72% with Ambient Light Sensor and HD IR camera (1920 x 1080)
33.80 cm (13.30 in) diagonal FHD IPS BrightView LED-backlit touch screen with Corning Gorilla Glass 5, 400 cd/m2, 72% with Ambient Light Sensor and HD IR camera WWAN (1920 x 1080)
33.80 cm (13.30 in) diagonal FHD IPS Anti-Glare LED-backlit touch screen with Corning Gorilla Glass 5, 400 cd/m2, 72% with Ambient Light Sensor and HD IR camera WWAN (1920 x 1080)
note: |
HDMI
Supports resolution up to 4k at 30 Hz.
Memory
Specification
Configurations
32 GB DDR4-2400 SDRAM (2 x 16 GB)
16 GB DDR4-2400 SDRAM (1 x 16 GB)
16 GB DDR4-2400 SDRAM (2 x 8 GB)
8 GB DDR4-2400 SDRAM (2 x 4 GB)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Maximum
note:Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Storage/drives
Specification
Primary storage
128 GB M.2 SATA-3 SS TLC
256 GB PCIe NVMe M.2 SS
256 GB PCIe Gen3x4 NVMe M.2 SS TLC
256 GB M.2 SATA-3 SED SS TLC (Opal 2)
512 GB PCIe Gen3x4 NVMe M.2 SS TLC
512 GB PCIe Gen3x4 NVMe M.2 SED SS TLC (OPAL 2)
512 GB M.2 SATA-3 SS TLC (FIPS 140-2)
1 TB PCIe Gen3x4 NVMe M.2 SS TLC
2 TB PCIe Gen3x4 NVMe M.2 SS TLC
note:For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Ports/slots
Specification
Ports
(2) USB 3.1 Type-C with Thunderbolt support
(2) USB 3.1 Gen 1 (1 charging)
(1) HDMI 1.4b port (cable sold separately)
(1) External Nano SIM tray (optional)
(1) Headphone/microphone combo jack
(1) AC power port
Slot
(1) Smartcard Reader (optional)
note: |
Audio/multimedia
Specification
Audio
Bang & Olufsen
Integrated 3 Multi Array Microphone
(2) Integrated stereo speakers
Camera
HD camera
HD IR camera
note: |
Networking/communication
Specification
WLAN
Intel Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) WLAN and Bluetooth 4.2 Combo, vPro
Intel Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) WLAN and Bluetooth 4.2 Combo, non-vPro
note: |
WWAN
Intel XMM 7262 LTE-Advanced CAT 6
Intel XMM 7360 LTE-Advanced CAT 9
Intel XMM 7560 LTE-Advanced Pro CAT 16
NFC
NXP NPC300 Near Field Communication Module
Miracast support
Yes
Keyboards/pointing devices/function keys
Specification
HP Premium keyboard
HP Premium Collaboration Keyboard
Backlit
Spill resistant with drain
Pointing devices
Clickpad with multi-touch gestures enabled (taps enabled as default)
Microsoft Precision Touchpad default gestures support
Function keys
F1 – Display switching
F2 – Blank or privacy
F3 – Brightness down
F4 - Brightness up
F5 - Audio mute/unmute
F6 - Volume down
F7 - Volume up
F8 - Microphone mute/unmute
F9 - Backlit toggle
F10 - Num Lock
F11 - Wireless
F12 - Calendar
Share/Present
Call Answer
Call End
Function Keys
Fn+R - Break
Fn+S - Sys Rq
Fn+C - Scroll Lock
Fn+E - Insert
Fn+W - Pause
Power
Specification
Power supply
Adapters
HP Smart 45 W External AC power adapter
HP Smart 65 W External AC power adapter
HP Smart 65 W USB-C External AC power adapter
HP 45 W USB Type-C adapter
HP 65 W USB Type-C adapter
note: |
Power cord
1.0 m (3.28 ft) - Duckhead power cord with 3-wire plug
1.8 m (5.9 ft) - Duckhead power cord, 3-wire plug
Primary battery
4-cell, 53 WHr HP Long Life Li-ion
note: |
Weight/dimensions
Specification
Starting at 1.35 kg (2.97 lb)
note: |
Dimensions (W x D x H)
30.66 x 21.52 x 1.69 cm (12.07 x 8.47 x 0.67 in)
Software/security
Specification
BIOS
Master Boot Record Security
BIOS Update via Network
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
HP Wireless Wakeup
Absolute Persistence Module
note: |
Communication/connectivity
HP Native Miracast support
HP Connection Optimizer
HP Value add software
HP Hotkey Support - CMIT
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP LAN-Wireless Protection
HP Sure Click
note: |
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
Ivanti Management Suite
HP Power Manager
HP Management Integration Kit for Microsoft SCCM (available for download)
note: |
Client Security software
Microsoft Defender (opt in and internet connection required for updates)
HP Client Security Suite Gen4 (requires Windows)
HP Security Manager (including Credential Manager and HP Password Manager, and HP Spare Key)
HP Device Access Manager
HP Power On Authentication
HP Fingerprint Sensor
Other standard security features
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
SATA 0 and 1 port disablement (via BIOS)
RAID (optional and requires a second hard drive)
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
Support for chassis padlocks and cable lock devices
HP Sure Click
HP Sure Start Gen4
HP Sure Run
HP Sure Recover
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
