    Fix HP Printer issue on macOS
HP LaserJet Pro MFP M428, M429, M479 - Setting up the printer to send and receive faxes
Before you begin
Complete the printer setup before connecting the fax service.
IMPORTANT: When connecting the printer to the telephone jack, use the telephone cable and adapters that shipped with the printer. Do not use other phone cables as it might cause problems with fax transmission.
Some countries/regions might require an adapter for the telephone cable that came with theprinter.
Depending on the phone connection type, you might need a line-splitter and additional two-wire telephone cables to complete the fax set up.
Look for the following icons on the rear of the printer to identify the telephone line-out port and the fax port:
On some printer models, the fax ports are behind a cover. To access the ports, remove the cover.
On some printer models, the fax port might be above the phone port.
Figure : Telephone line-out port (top) and fax port (bottom)
Follow the steps below in the order presented to set up the fax.
Click a step heading to expand the section.
Video overview
In addition to the instructions provided in this document, you can view the following video of how to set up the printer to send and receive faxes:
If you are unable to view the video above, or to view the video in a different size, click here to watch the video on YouTube.
