Product Specifications for the HP Laser 107w (4ZB78A)
Product naming
Model name
HP Laser 107w
4ZB78A
What's included and accessories
What's in the box
Preinstalled introductory HP LaserJet Black print cartridges (~0.5K pages, WW); Setup Guide; Reference Guide; Regulatory Statements Flyer; Power cord; USB cable
Connectivity
Ports
Hi-Speed USB 2.0 port, Wireless 802.11 b/g/n
Wireless capability
Yes, built-in Wi-Fi 802.11b/g/n
Environmental
Acoustic power emissions (active, printing)
6.5 B(A)
Recommended operating humidity range
20 to 70% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 27°C
Recommended operating temperature range (Fahrenheit)
59 to 80.6°F
Storage temperature range (Celsius)
-20 to 40°C
Storage temperature range (Fahrenheit)
-4 to 104°F
Environmental specifications
Mercury free
Memory
Memory
64 MB
Maximum Memory
64 MB
Memory card compatibility
None
Mobile printing capability
Mobile printing services
Apple AirPrint™; Google Cloud Print™; Mobile Apps; Mopria™ Certified; Wi-Fi® Direct printing
Networking
Network protocols, supported
Via built-in networking solution: TCP/IP, IPv4, IPv6; print: TCP-IP port 9100 Direct Mode, LPD (raw queue support only), Web Services Printing; discovery: SLP, Bonjour, Web Services Discovery; IP Config: IPv4 (BootP, DHCP, AutoIP, Manual), IPv6 (Stateless Link-Local and via Router, Stateful via DHCPv6); management: SNMPv1/v2/v3, HTTP
Paper handling
Input capacity
Up to 150 sheets
Standard input capacity (envelopes)
Up to 10
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A4; A5; A5(LEF); B5 (JIS); Oficio; Envelope (DL, C5); 76 x 127 to 216 x 356mm
Media sizes supported (U.S. standard)
Letter; Legal; Executive; Oficio 216x340mm, Oficio 8.5x13 in, Envelope (No.10, Monarch); 4x6 in
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Plain, Thick, Thin, Cotton, Color, Preprinted, Recycled, Labels, CardStock, Bond, Archive, Envelope
Media weight supported (metric)
60 to 163 g/m²
Media weight supported (U.S. standard)
16 to 43 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
331 x 350 x 248 mm
Maximum dimensions (W x D x H, U.S. standard)
13.03 x 13.78 x 9.76 in
Weight (metric)
4.16 kg
Weight (U.S. standard)
9.17 lb
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology; Power save
Internal (built-in) Power Supply
Power supply
110-volt input voltage: 110 to 127 VAC, 50/60Hz and 220-volt input voltage: 220 to 240 VAC, 50/60Hz
Power consumption
320 watts (Active Printing), 33 watts (Ready), 1.1 watts (Sleep), 0.2 watts (Manual off), 0.2 watts (Auto off/Manual on)
Print cartridges
Number of print cartridges
1 (black)
Replacement cartridges
HP 105A Black Original Laser Toner Cartridge ( 1000 yield) W1105A; HP 106A Black Original Laser Toner Cartridge ( 1000 yield) W1106A; HP 107A Black Original Laser Toner Cartridge ( 1000 yield) W1107A
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 1,200 x 1,200 dpi
Maximum print area (metric)
216 x 356 mm
Monthly duty cycle
Up to 10,000 pages
Print languages
SPL
Printer smart software features
Manual duplex, N-up printing, collation, watermarks, accepts a variety of paper sizes and types
Regulatory specifications
Regulatory model number
SEOLA-1802-01
Safety
IEC 60950-1: 2005 +A1: 2009 +A2 2013 (International); EN 60950-1: 2006 +A11: 2009 +A1: 2010 +A12: 2011 +A2: 2013 (EU); IEC/EN 60825-1: 2014 (Class 1 Laser Product); EN 62479: 2010 /IEC 62749: 2010; Low Voltage Directive 2006/95/EC with CE Mark (Europe); GS Certificate (Germany, Europe); UL/cUL Listed and UC CoC (US/Canada); CAN/CSA C22.2 No. 60950-1-07 2nd Ed. 2014-10; Compliance with Laser safety standards 21 CFR 1002.10 and 1002.11 except for deviations pursuant to Laser notice No. 50, Dated June 24, 2007; Other safety approvals as required by individual countries
Electromagnetic compatibility
EN 61000-3-2: 2014, EN 61000-3-3: 2013, EN55024: 2010, EN 55032: 2012/AC: 2013, 47 CFR Part 15, Subpart B I ANSI C63.4-2009, ICES-003 Issue 5, KN32, KN35, GB/T 9254-2008, GB17625.1-2012, CISPR22: 2008, CISPR32: 2012,CNS 13438 (Other EMC approvals as required by individual countries.)
Security
Security management
Password-protected network embedded Web server; enable/disable Network ports; SNMPv1 community password change; SNMPV2&V3; IPSec; Filtering : MAC, IPv4, IPv6
System requirements
Minimum system requirements for Windows
Windows 7 or newer, Intel® Pentium® IV 1 GHz 32-bit or 64-bit processor or higher, 1 GB RAM, 16 GB HDD
Compatible Network Operating Systems
Windows®: 7 (32/64 bit), 2008 Server R2, 8 (32/64 bit),10 (32/64 bit), 2012 Server, 2016 Server
Operating system (supported note)
Windows 7 or higher
One-year limited hardware warranty; For more info please visit us at https://support.hp.com
