Model name
HP Color Laser MFP 179fnw
4ZB97A
- ${title}
- ${title}
- ${title}
- ${title}
Product Specifications for the HP Color Laser MFP 179fnw (4ZB97A)
Product naming
What's included and accessories
What's in the box
Preinstalled introductory HP Laser Printer 0.7 K pages Black , 0.5 K pages Cyan, Yellow, Magenta print cartridges; Imaging drum, Toner collection unit; Installation guide, Getting Started guide, User's Guide, Support flyer, Warranty guide; No CD-ROM; Power cord; USB cable (WW); tel line cable
Connectivity
Ports
Hi-speed USB 2.0 port, Fast Ethernet 10/100Base-Tx network port, Wireless 802.11 b/g/n
Wireless capability
Yes, built-in Wi-Fi 802.11 b/g/n
Copy
Copier settings
Copies; Original Size; Reduce/Enlarge; Darkness; Original Type; Collation; 2-Up; 4-Up; ID Copy; Adjust Background; Auto Fit Copy; Color Mode
Maximum number of copies
Up to 999 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed (color, normal)
Up to 4 cpm
Copy speed (black, normal)
Up to 18 cpm
Copy resolution
Up to 600 x 600 dpi (flatbed); Up to 600 x 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.5 B(A) (printing at with Mono mode); 6.1 B(A) (printing at with Color mode)
Recommended operating humidity range
20 to 70% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 27°C
Recommended operating temperature range (Fahrenheit)
59 to 80.6°F
Storage temperature range (Celsius)
-20 to 40°C
Storage temperature range (Fahrenheit)
-4 to 104°F
Environmental specifications
Mercury free
Fax
Fax features
Permanent fax memory backup, color faxing, auto fax reduction, auto redialing, delayed sending, fax forwarding, PC fax, Secure receive
Fax Resolution Black (best)
Up to 300 x 300 dpi
Fax memory
Up to 400 pages
Telephone handset supported
No
Fax telephone mode supported
Yes
Modem
33.6 kbps
Fax Speed Dials, Maximum Number
Up to 100 numbers
Fax transmission speed (letter)
33.6 kbps
Memory
Memory
128 MB
Maximum Memory
128 MB
Mobile printing capability
Mobile printing services
Apple AirPrint™; Mobile Apps; Google Cloud Print™; Wi-Fi® Direct Printing; Mopria™ Certified
Networking
Network protocols, supported
Via built-in networking solution: TCP/IP, IPv4, IPv6; print: TCP-IP port 9100 Direct Mode, LPD (raw queue support only), Web Services Printing; discovery: SLP, Bonjour, Web Services Discovery; IP Config: IPv4 (BootP, DHCP, AutoIP, Manual), IPv6 (Stateless Link-Local and via Router, Statefull via DHCPv6); management: SNMPv1/v2/v3, HTTP
Paper handling
Input capacity
Up to 150 sheets
Output capacity
Up to 50 sheets
Media sizes supported (metric)
Tray1: A4; A5; A6; B5 (JIS); Oficio 216 x 340. Tray2: Not supported; Optional Automatic duplexer: Not supported
Media sizes supported (U.S. standard)
Tray 1: Letter, Legal, Executive, Oficio 8.5 x 13, 4 x 6. Tray 2: Not supported; Optional Automatic Duplexer: Not Supported
Media sizes, custom (metric)
76 x 148.5 to 216 x 356 mm
Media sizes, custom (U.S. standard)
3 x 5.85 to 8.5 x 14 in
Media types
Plain, Light, Heavy, Extra Heavy, Colored, Preprinted, Recycle, Labels, Bond, Glossy
Media weight supported (metric)
60 to 220 g/m²
Media weight supported (U.S. standard)
16 to 59 lb
Paper handling - ADF
Automatic document feeder capacity
Standard, 40 sheets
Media size (ADF)
B5
Media weight supported, ADF (metric)
60 to 105 g/m²
Media weight supported, ADF (U.S. standard)
16 to 28 lb
Physical dimensions
Maximum dimensions (W x D x H, metric)
421.9 x 422.9 x 344.1 mm
Maximum dimensions (W x D x H, U.S. standard)
16.61 x 16.65 x 13.55 in
Weight (metric)
14.08 kg
Weight (U.S. standard)
31.05 lb
Power
Internal (Built-in) power supply
Power supply
110-volt input voltage: 110 to 127 VAC, 50/60 Hz and 220-volt input voltage: 220 to 240 VAC, 50/60 Hz
Power consumption
300 watts (Active Printing), 38 watts (Ready), 1.9 watts (Sleep), 0.2 watts (Manual off)
Print cartridges
Number of print cartridges
4 (1 each black, cyan, magenta, yellow)
Replacement cartridges
HP 116A Original Laser Toner Cartridge (~1000/~700 pages) W2060A/W2061A/W2062A/W2063A (AMS); HP 117A Original Laser Toner Cartridge (~1000/~700 pages) W2070A/W2071A/W2072A/W2073A (EMEA); HP 118A Original Laser Toner Cartridge (~1000/~700 pages) W2080A/W2081A/W2082A/W2083A (China Only); HP 119A Original Laser Toner Cartridge (~1000/~700 pages) W2090A/W2091A/W2092A/W2093A (APJ excl China); Drum WW (less China) W1120A; Drum (China only) W1132A
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 600 x 600 dpi
Maximum print area (metric)
216 x 356 mm
Monthly duty cycle
Up to 20,000 pages
Print languages
SPL
Printer smart software features
Manual duplex and booklet print, N-up printing, skip blank pages, poster print, watermarks
Regulatory specifications
Regulatory model number
SEOLA-1801-05
Energy efficiency
CECP
Safety
IEC 60950-1: 2005 +A1: 2009 +A2 2013 (International); EN 60950-1: 2006 +A11: 2009 +A1: 2010 +A12: 2011 +A2: 2013 (EU); IEC/EN 60825-1: 2014 (Class 1 Laser Product); EN 62479: 2010 /IEC 62749: 2010; Low Voltage Directive 2006/95/EC with CE Mark (Europe); GS Certificate (Germany, Europe); UL/cUL Listed and UC CoC (US/Canada); CAN/CSA C22.2 No. 60950-1-07 2nd Ed. 2014-10; Compliance with Laser safety standards 21 CFR 1002.10 and 1002.11 except for deviations pursuant to Laser notice No. 50, Dated June 24, 2007; Other safety approvals as required by individual countries
Electromagnetic compatibility
EN 61000-3-2: 2014, EN 61000-3-3: 2013, EN55024: 2010, EN 55032: 2012/AC: 2013, 47 CFR Part 15, Subpart B I ANSI C63.4-2009, ICES-003 Issue 5, KN32, KN35, GB/T 9254-2008, GB17625.1-2012, CISPR22: 2008, CISPR32: 2012, CNS 13438 (Other EMC approvals as required by individual countries.)
Telecom compliance (fax capability)
EBR21, FCC Prat 68
Scan
Scanner advanced features
Scan to WSD (network support only);Book Scanning; Poster Stitching for multiple scan; Text Converting; Scan to E-Book; Existing File to E-Book
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 4,800 x 4,800 dpi
Levels of grayscale
256
Bit depth
10-bit (color)
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.7 in
Minimum ADF scan size (metric)
145 x 145 mm
Minimum ADF scan size (U.S. standard)
5.7 x 5.7 in
Maximum ADF scan size (metric)
216 x 356 mm
Maximum ADF scan size (U.S. standard)
8.5 x 14 in
Twain version
Version 1.9
Security
Security management
Password-protected network embedded Web server; enable/disable Network ports; SNMPv1 community password change; SNMPV2&V3; IPSec; Filtering : MAC, IPv4, IPv6
System requirements
Minimum system requirements for Windows
Windows 7 or newer, Intel® Pentium® IV 1 GHz 32-bit or 64-bit processor or higher, 1 GB RAM, 16 GB HDD
Compatible Network Operating Systems
Windows®: 7 (32/64 bit), 2008 Server R2, 8 (32/64 bit),10 (32/64 bit), 2012 Server, 2016 Server
Operating system (supported note)
Windows 7 or higher
One-year limited hardware warranty; For more info please visit us at https://support.hp.com
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
