HP LaserJet Pro MFP M329, M428-M429, M479 - Scan to a network folder
Use the printer control panel to scan a document and save it to a folder on the network.
In order to use this feature, the printer must be connected to a network and the Scan to Network Folder feature must be configured by using the Scan to Network Folder Setup Wizard (Windows) or the HP Embedded Web Server. For instructions on configuring the feature, go to Set up Scan to Network Folder.
In addition to the instructions provided below, you can view the following video of how to scan to a network folder using your HP LaserJet Pro printer:
If you are unable to view the video above, or to view the video in a different size, click here to watch the video on YouTube.
  1. Load the document on the scanner glass or into the document feeder according to the indicators on the printer.
  2. From the Home screen on the printer control panel, touch the Scan icon, and then touch the Network Folder icon.
  3. In the list of network folders, select the folder to which you want to save the document.
  4. If prompted, enter the PIN.
  5. Select a file type from the Save As list.
  6. Touch <Filename> and use the keypad to assign a name to the scanned file. Touch Done.
  7. If you want to preview the scan or change the scan options, do the following:
    • To preview the scan, touch the Preview icon or Touch to Preview. (The scan preview option varies depending on the printer model.)
    • For additional scan options, touch the Settings icon .
  8. Touch Send or Start Scan.
