HP ENVY - 17-bw0004nb Product Specifications
4BZ97EA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2400 SDRAM (2 x 4 GB)
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 7200 rpm SATA
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
41.6 x 27.8 x 2.31 cm
2.9 kg
65 W AC power adapter
3-cell, 52.5 Wh Li-ion
Battery life mixed usage
Up to 12 hours and 45 minutes
Video Playback Battery life
Up to 12 hours and 30 minutes
Bang & Olufsen, dual speakers, HP Audio Boost
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
