HP PrinterOn Enterprise - What languages are supported by the PrinterOn PrintWhere desktop application?
  • Currently the PrinterOn PrintWhere application supports English only from the Graphical User Interface.
  • The PrinterOn PrintWhere application can be installed on any supported Windows based machine with any language; since the application is not reliant on the language.
  • Can PrinterOn PrintWhere render any language? Yes, PrintWhere uses the installed printer driver to render a print job; therefore if the printer driver supports the language being rendered then this will be successful.
Applies to PrinterOn PrintWhere 6.x and later.
