HP Laser Printers - Creating Custom Paper Sizes
This document is for the HP Laser 100, 150, 1000, MFP 130, 170, and 1000 Printer Series.
Print to any size paper within the minimum and maximum printing dimensions supported by your printer.
To avoid print quality problems and other issues, make sure your custom size does not exceed the actual size of your paper.
