    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP PrinterOn Enterprise - First Time Logging into the PrinterOn Configuration Manager
Logging into the the PrinterOn Configuration Manager is accomplished by using:
  • URL: https://127.0.0.1:8057 (default port, additionally access is only over https)
  • Username - root
  • Password - APIsiteAuth value found in your license file
Once you have connected successfully, password change screen will be presented to generate and save a new password for the root account.
The limitations on this password are:
  1. Username must not be present in password.
  2. Password must not have 4 or more consecutive letters or digits.
  3. If 8-9 characters it needs at least 1 letter, 1 number, and 1 special character.
  4. If 10+ characters, then two characters are needed from two of these three categories.
  5. Letters.
  6. Numbers.
  7. Special Characters.
Applies to PrinterOn Enterprise 3.x and later.
