HP PrinterOn Enterprise - How to customize PrinterOn Web Print Interface with a customized logo?
The PrinterOn Enterprise solution web interface can be customized with a new logo, these steps below will outline the steps required to accomplish this.
  1. Navigate to this default location: C:\Program Files (x86)\PrinterOn Corporation\Apache Tomcat\webapps\cps\images\new
  2. Rename the file logo_white.png to another value e.g: logo_white_original.png
  3. Copy the new logo file that you want to appear on the web print page to the name logo_white.png
The height of the log file is hard coded within the pages for the web submission page, however using CSS coding we can change only the height property, the step below will help to accomplish this change:
  • Copy the below code directly into the custom.css file located in this directory by default: C:\Program Files (x86)\PrinterOn Corporation\Apache Tomcat\webapps\cps\css
navbar-brand{
#background-image: url("../images/new/logo_white.png")!important;
#width: 205px;
height: 80px !important;
#border: 0px;
The Height attribute was changed from 70 (the default value) to 80, the larger size required.
