    Fix Windows 10 Update Issues
HP LaserJet Managed MFP E82540-E82560, HP Color LaserJet Managed MFP E87640-E87660 - Supported paper sizes and types
Use the following information to check paper sizes and types that are compatible with your printer. To obtain the best results, select the correct paper size and type in the print driver before printing.
The paper sizes in the following table are supported by your printer. Each paper size is followed by the specific trays and other printer components that are compatible wth the paper size.
Paper size
Compatible trays/components
Letter: 215.9 x 279.4 mm
Tray 1, Tray 2, Tray 3, Duplex, ADF
Letter Rotated: 279.4 x 215.9 mm
Legal: 215.9 x 355.6 mm
Ledger: 279.4 x 431.8 mm
Tray 1, Tray 3, Duplex, ADF
Executive: 184.2 x 266.7 mm
Statement: 139.7 x 215.9 mm
Oficio: 215.9 x 330.2 mm
Arch B: 304.8 x 457.2 mm
4 x 6: 101.6 x 152.4 mm
Tray 1, Tray 2
5 x 7: 127 x 177.8 mm
Tray 1, Tray 2
5 x 8: 127 x 203.2 mm
Tray 1, Tray 2
A6: 105 x 148 mm
Tray 1, Tray 2
8K: 260 x 368 mm
8K: 270 x 390 mm
8K: 273 x 394 mm
16K: 184 x 260 mm
16K: 195 x 270 mm
16K: 197 x 273 mm
A3: 297 x 420 mm
A4: 210 x 297 mm
A4 Rotated: 297 x 210 mm
A5: 148 x 210 mm
A5 Rotated: 210 x 148 mm
A6: 105 x 148 mm
SRA3: 320 x 450 mm
RA4: 215 x 305 mm
B4 (JIS): 257 x 364 mm
B5 (JIS): 182 x 257 mm
B6 (JIS): 128 x 182 mm
Postcard (JIS): 100 x 148 mm
Tray 1, Tray 3
DPostcard (JIS): 148 x 200 mm
Envelope #9: 98.4 x 225.4 mm
Tray 1, Tray 2
Envelope #10: 104.8 x 241.3mm
Tray 1, Tray 2
Envelope Monarch: 98.4 x 190.5 mm
Tray 1, Tray 2
Envelope B5: 176 x 250 mm
Envelope C5: 162 x 229 mm
Envelope C6: 114 x 162 mm
Envelope DL: 110 x 220 mm
Custom media sizes: 98–320 x 139.7–457.2 mm
Tray 1
Custom media sizes: 98–297 x 139.7–390 mm
Tray 2
Tray 3
Supported paper types
The following paper types are compatible with your printer.
  • Plain
  • HP EcoFFICIENT
  • HP Matte 90g
  • Light 60-74g
  • Intermediate 85-95g
  • Light Bond
  • Bond
  • Heavy Bond
  • Recycled
  • HP Matte 105g
  • HP Matte 120g
  • HP Soft Gloss 120g
  • HP Glossy 120g
  • Mid-Weight 96-110g
  • Heavy 11-130g
  • Mid-Wt Glossy 96-110g
  • Heavy Glossy 111-130g
  • HP Matte 150g
  • HP Glossy 150g
  • Extra Heavy 131-175g
  • Extra Heavy Glossy 131-175g
  • HP Matte 150g
  • HP Glossy 200g
  • Cardstock 176-220g
  • Card Glossy 176-220g
  • Light Paperboard 221-255g
  • Paperboard 256-300g
  • Heavy paperboard
  • Mono transparency
  • Labels
  • Letterhead
  • Envelope
  • Heavy Envelope
  • Preprinted
  • Prepunched
  • Colored
